postgreSQL psql
postgres, mysql, mongodb
Post Reply
dev
Site Admin
postgreSQL psql
Post by dev »
psql -U postgres
Some interesting flags (to see all, use -h or --help depending on your psql version):
-E: will describe the underlaying queries of the \ commands (cool for learning!)
-l: psql will list all databases and then exit (useful if the user you connect with doesn't has a default database, like at AWS RDS)
Most \d commands support additional param of __schema__.name__ and accept wildcards like *.*
\?: Show help (list of available commands with an explanation)
\q: Quit/Exit
\c __database__: Connect to a database
\d __table__: Show table definition (columns, etc.) including triggers
\d+ __table__: More detailed table definition including description and physical disk size
\l: List databases
\dy: List events
\df: List functions
\di: List indexes
\dn: List schemas
\dt *.*: List tables from all schemas (if *.* is omitted will only show SEARCH_PATH ones)
\dT+: List all data types
\dv: List views
\dx: List all extensions installed
\df+ __function__ : Show function SQL code.
\x: Pretty-format query results instead of the not-so-useful ASCII tables
\copy (SELECT * FROM __table_name__) TO 'file_path_and_name.csv' WITH CSV: Export a table as CSV
\des+: List all foreign servers
\dE[S+]: List all foreign tables
\! __bash_command__: execute __bash_command__ (e.g. \! ls)
User Related:
\du: List users
\du __username__: List a username if present.
create role __test1__: Create a role with an existing username.
create role __test2__ noinherit login password __passsword__;: Create a role with username and password.
set role __test__;: Change role for current session to __test__.
grant __test2__ to __test1__;: Allow __test1__ to set its role as __test2__.
\deu+: List all user mapping on server
Post Reply
