cmd cmd.exe command line win
tips & tricks
Post Reply
dev
Site Admin
Post by dev »
Code: Select all
netstat –nao
netstat -ao |find /i "listening"
Show all TCP and UDP port usage and process ID:
netstat –nao
Look for usage of port [port] every [N] seconds
netstat –nao [N] | find [port]
Dump detailed protocol statistics
netstat –s –p [tcp|udp|ip|icmp]
Code: Select all
netsh winsock reset
ipconfig /release
netsh int ip reset
ipconfig /flushdns
ipconfig /renew
https://www.sans.org/security-resources ... eet_v1.pdf
http://www.cs.columbia.edu/~sedwards/cl ... tsheet.pdf
Post Reply
